hi...
we have bottom fired boiler and in every boiler 2 scanner is installed, (fireye make flame scanner. the scanner model 85phonexIR)
we used F.O.(Furnace Oil)as fuel.
the problem is, being bottom fired some parts of furnace oil are snagged in scanner head (as the oil through with a high pressure and it reflect from the roof of the furnace) and also on the head of orifice (as we used orifice for control the flame intensity) for that matter we won't be able to operate the scanner for a long time.
* the air pressure in the boiler is 6kg,
* we used T connector in the sight pipe of flame scanner.
* we won't have any swivel mount.
* the pipe 4inch long in the inner side of the boiler.
* the purging air to the flame scanner (the valve is installed in between T connector and the air pipe joint) is passed though 1/2" NPT valve.
anyone can suggest the way to remove this problem?
