Jump to a Date
Twitter Feed
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Beware of the Turing Tar-pit in which everything is possible but
nothing of interest is easy.
www.control.com/rss/
Need soft PLC code generator (ladder logic, structured text, flow chart etc) for PC and interpreter written in C.
Please let me know if anybody come up with any names ..
Thanks,
Ratin
LinuxPLC mailing list
LinuxPLC@linuxplc.org http://lists.linuxplc.org/mailman/listinfo/linuxplc
Thanks,
Ratin
Mohammed Rahman:
> chart
The MAT LinuxPLC has a translator from ladder logic mnemonics to C. See the documentation at
http://mat.sf.net/manual/logic/il.html
or the logic/il directory in the CVS.
Does the basic rung instructions (LD, AND, OR, OUT, SET, RST), as well as master control (MCS, MCE), rung combination (ANB, ORB), jumps (JMP, LBL) and subroutines (JSR, SUB).
Jiri
Jiri Baum <jiri@baum.com.au> http://www.csse.monash.edu.au/~jirib
MAT LinuxPLC project --- http://mat.sf.net --- Machine Automation Tools _______________________________________________
> chart
Jiri
I looked at the code once. Arent they written using some specific graphics Libraries supported under linux? Actually I need the GUI on a PC environment. I don't know if anybody written anything yet..
Ratin
Ratin
Mohammed Rahman:
Actually, the one I was thinking of has no graphics at all - it takes a text file of mnemonics and translates it to C.
It should run under Windows no problem, because it's a Perl script with no fancy stuff (just be careful about line-ends).
There is a graphic one, which executes the logic directly, as an interpreter - but yes, that's going to be a fair bit of work to port to MS. If you want to use it, go to its original site
http://classicladder.sf.net
because MAT doesn't have the latest version yet.
Jiri
Jiri
Look at "www.neumaflo.com.au":http://www.neumaflo.com.au
Does exactly what you want.
Look @ "http://cubloc.com"
they have nice Ladder Logic controllers even though not programmable in Linux...
