Din-Rail mount Modbus Plus tap
Local and wide area networking in factory automation. topic
Posted by CK on 6 February, 2002 - 4:56 pm
I am trying to locate a vendor I had found once before who makes a small DIN-rail mounted Modbus Plus tap. This tap was similar in design
to the CableFast I/O bases and Weidmuller DIN-rail mounted connection bases. The Modbus Plus trunk cable went in and out screw terminals on
the sides (over the DIN rail) and the drop cable connected on the bottom of the front, also on screw terminals. It was also fairly inexpensive. It would be a really nice solution to a problem with lack of space I have in an enclosure. Looking for a vendor name, phone,
web address, anything. I know this device exists, I just can't find it again!
CK
Posted by C Turner on 8 February, 2002 - 11:02 am
"http://www.grantindustrial.com/modbus_plus_taps.htm":http:/ /www.grantindustrial.com/modbus_plus_taps.htm
i think they have what you need
Posted by Steve Young on 9 February, 2002 - 12:56 pm
The device you are talking about in Made by Phoenix Contact. The Order number is 5602112. You can find more information about it on our
web site at "http://www.grantindustrial.com/modbus_plus_taps.htm":http:/ /www.grantindustrial.com/modbus_plus_taps.htm
It is Din Rail Mounted, has screw terminal connection for the trunk and drop cables, and has a switch to select if a terminating resistor
mounted on the module is connected for end of line or not.
If I can be of assistance my email is syoung@grantindustrial.com
Unfortunately this is a custom product made by Phoenix Contact, therefore you will not find any information on their web site.
Posted by Jeremy Rutka on 18 June, 2002 - 12:28 pm
Phoenix contact has a Modbus plus tap and has a list price of about $50
You may email me or call me at 1800-890-2820
Thanks,
Jeremy Rutka
Technical Advisor
Posted by Ed Finley on 30 September, 2012 - 5:38 pm
We have them. We had Phoenix make them for our Company. Call Power Resources at 631-643-3170
Only adults have difficulty with childproof caps.
Advertise here
Advertisement
our advertisers
