from the department...
Intouch LGH File
Software, including programming, OS issues, etc. topic
Posted by Marcelo Murta on 19 May, 2002 - 9:31 am
We have an application based on the Wonderware Intouch SCADA that generates a ".LGH" file with historical data that we would like to read with standard software such as Excel or Access.
Is there any way to convert this file to a ".mdb" one?
Is the ".LGH" file format known to anyone?
TIA,
Marcelo Murta
mmurta@prover.com.br
Posted by Trevor Ousey on 20 May, 2002 - 11:34 am
Look at the Histdata program installed with Intouch.
Posted by Waseem Butt. Intech Process Automation Inc. on 20 May, 2002 - 2:19 pm
Hi Marcelo,
Wonderware provides HistData utitity to extract data in Excel. You can find its object in Intouch standard wizards. You may have to write macros to read data in Excel. Intoch's help does provide sample macros and commands to read data in Excel.
Posted by Ravi Subramanian on 20 May, 2002 - 2:59 pm
You have 2 choices. Wonderware comes standard with Histdata. You can write scripts that can read the LGH files and write a CSV file that excel can read. All this functionality comes standard with Wonderware.
If you want more control, you can buy Wonderware's subroutines that will let you access the data directly. There are a bunch of other programs that Wonderware sells that will let you do this.
Posted by Anonymous on 20 May, 2002 - 3:01 pm
LGH and IDX are binary that are unreadible or accessable except with the Hist Data utilty.
The Hist Data utilty is provided by WW and comes with InTouch. For more look in the InTouch Users Guide Ch8 Real-Time and Historical Trending (HistData Utility Program) and Tech Note 91.
The simple way is using the HistData wizard that works off/conjunction with the Historical Trend chart.
Posted by Domnic on 20 April, 2008 - 4:46 pm
One way to get over this problem is to config the alarm printer. In the configuration, disable the Print option. All the vents will be logged in an agl file. No. of days to retain the files can be decided by you.
Domnic
Posted by Dan Jones on 22 September, 2010 - 12:08 pm
Try using WorkSmart Automation's ReportBuilder with ODBC connector to Wonderware InTouch. You can download a 30 day evaluation for free. The ODBC connector serves up data to ReportBuilder Excel Add-in and you can build workbooks to report lgh data for dynamic time frames making it very simple to report hourly, daily, and monthly data straight from the .lgh files. Go to www.worksmartautomation.com for more information.
Posted by Jim @ SyTech on 24 September, 2010 - 4:25 pm
The product XLReporter (www.TheReportCompany.com) does it easily. You can try it for free. Go to their technical note on how to set up XLReporter for .LGH files at
http://www.thereportcompany.com/download/Tech_InTouch.pdf
With XLReporter you'll use Excel as the "design studio" to make your templates and you'll run it in XLReporter.
Larkinson's Law:
All laws are basically false.
Advertise here
Advertisement
our advertisers
