Modbus Utility
E
Ed Lee
I need a simple utility to run on my PC and communicate with a Modbus RTU slave to verify commications works with the slave. I only need it as a utility for checking stuff out. Does anybody have one/sell one???
You can use ModLink Software from Modicon. This is a DDE utolity you can link to Excel or a Visiual basic application. The ref is 352SMD49300.
You can get "Modbus test software" from
modicon support bbs. The program is older and unsuported but works just fine. Here is the procedure you need to follow:
1. go to "bbs.modicon.com/signup/supform":http://bbs.modicon.com/signup/supform and create an account for you
2. When your are done select "File Libraries" or go to "bbs.modicon.com/library/":http://bbs.modicon.com/library/
3. Search for MTS
4. Download MTS302.zip
I hope this helps
Haris
P
Praveen Mathew
U can give a google search on "Modbus Simulator".
The best on available is from Calta Systems , which can act as both slave 7 Master
