In my home shop I have a Delta 31-695 sander which I received second hand. It has a 120VAC capacitor start motor. The from the circuit I have, the capacitor stays on while the motor is running. So far, I have replaced the motor, relay, capacitor (several capacitors), and toggle switch, which would be all the electrical components. The wires are in good shape. The relay coil appears to be solid #10 or #8 wire, so it should handle the current.
Now that I've replaced all the components, the sander will work fine for not much more than 30 seconds and then the capacitor will fail. It smokes and splatters oil and goey black smelly stuff. I have the following diagram that has one ambiguity that Delta tech support cannot clear-up for me: is the capacitor fed from the line or load side of the relay coil?
120v switch relay
blk---o/ o------o^^^o--------black motor wire
| ___ cap
+-o o---|(---red motor wire
wht--------------------------white motor wire
grn---------(machine ground screw)
So...
1. Why would a circuit with all new components result in the capacitor failure?
2. Is it important which side of the relay coil the capacitor power is fed from?
Thanks, Anthony Kerstens P.Eng.
120v switch relay
| ___ cap
So...
