T
Has anyone successfully used a V.92 modem as a Modbus RTU master to talk with a slave PLC. I have no problems with the earlier modem versions (e.g. 56k, etc.) as master and I have no problem with the V.92 as the slave modem. I just can't get the V.92 modem to talk when it is the master. The modems connect, but they don't talk. Even when disabling all the following (V.92 mode, compression, buffering, and error correction) via AT commands it still doens't work.
