G
I am in the unfortunate position of trying to pass TCP/IP messages (from a number of external sources) between two AB ControlLogix PLCs.
The client is providing a serial communication link (Modbus, Profibus, etc.) between the two PLCs and I need to pass TCP/IP messages over the link via the PLCs. The plan is to send the TCP/IP message to the PLC. The PLC then sends the message content over the serial link to the other PLC which then spits the message out with the correct TCP/IP header.
Has anyone tried this? A Prosoft card exists for the ControlLogix that accepts ASCII messages over TCP/IP but does not look at the TCP/IP header and requires a end character to indicate the end of the message. I know this sounds backwards but the restrictions are enforced for various reasons. The serial protocol is used for other messaging over which we have no control.
Has anyone else been forced to send TCP/IP messages encapsulated in Modbus, etc?
