Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
A real patriot is the fellow who gets a parking ticket and rejoices
that the system works.
www.control.com/rss/
People,
We have a permannet magnet, DC motor (rated voltage 36 V, torque 15 Ncm and speed 5 - 40 krpm), with two field coils. The drive uses a control circuit, ac-dc rectifier and a power H bridge type circuit to generate two quasi sine waves at 180 degrees phase shift. It seems feedback is by back E.m.f.
We need a similar drive which accepts a 0-10 Vdc speed signal and possibly able to drive five such motors concurrently (only one motor loaded).
Can someone suggest possible suppliers?
Martin
Martin
An AC drive now has the same zero speed torque that is avalible in the DC drives, so there is no reason not to use an AC drive.AC drives also have more applications and better speed control(0-10V or 4-20ma) than DC drives.
I know of a company that sells a new drive called the "PDL" it can operate a number of drives at one time. if you would like to switch to an AC drive E-Mail me and I will gladly give you the name and the number of the company.
HOWEVER, typically DC motors are considerably more robust then AC motors, as are the drives. Try pumping 150% current into an AC motor for 30 seconds or so and see what happens. A DC motor/drive combination will often survive this while an AC motor/drive combination will just trip.
There is also the regen problem. 4 quadrant DC drives are generally less expensive then full regen AC drives. This is a major advantage in some applications.
As for the better speed control idea, I think that is sheer nonsense. Digital DC drives with digital feedback have very similar speed control features as AC vector drive motors with digital feedback. Its true that older analog DC drives or using voltage feedback resulted in lower speed regulation that some AC drives, but this is not a problem associated with using a DC drive in and of itself, but not using the appropriate drive. besides, most digital feedback digital drives can easily maintain 1/2% speed accuracy (in some cases even better). Its not many applications that require anything a lot better than that.
One thing I have observed is that vector drive performance at very low turndowns (maybe < 1/4% of full speed) seem to perform better then a digital drive where you can sometimes see a bit of cogging. But very few applications require this kind of turndown.
Try comparing an AC vector drive/motor combination to a digital DC drive/motor combination where occasional current demand exceeds the motor spec for say 20 seconds twice a day, and regen capability is required. I bet you will be surprised at the cost comparison.
Bob Peterson
Bob Peterson
Concise and informative, would you say the advantages of dc over ac, and costs also apply to large drives and motors? my application requires traction control of a 40 kW motor from a DC source. regeneration/braking is a must.
thanks Bob
Alex
thanks Bob
Alex
People will use AC Motor to replace DC Motor most of the reason is on motor side, the AC motor are more maintanese free.
AC or bldc motors can also rotate at higher speeds since there is no mecanical commutation limitations.
Related articles from Control
Engineering magazine- Siemens announces motors, drives, and motion control advances
- OMAC guidelines ease design, programming, integration
- Motors, drives and motion control: Green Hills Software tapped for Saab UAV
- Motors, drives and motion control: Moving ahead at Solar Power International trade show
- Machine control: Robots go like a child in a sweetshop
- Machine control: Lack of wireless interoperability concerns industrial automation engineers
- Machine vision and discrete sensors: Laser scanner supports crime scene investigation
- Bosch Rexroth AG to purchase German companies
- Torque: Hall-effect sensor, reaction torque sensor, torque data acquisition
Subject to its Terms of Use.
