Water level is to be controlled within a band in a cylindrical tank.
One input valve and one output valve. High and low level switches. PLC generates a fixed pattern of operation for output valve...4sec open 7 sec closed. Input valve timing to be controlled. Can fuzzy or neuro fuzzy be used for control? No other inputs into controller.
Albert
Albert
