Choosing a PIMS
Software, including programming, OS issues, etc. topic
Posted by Marcio on 31 October, 2003 - 9:50 pm
We are in internal conversation to choose a PIMs, I´d like to know if someone have a datasheet to ranking PIMS with their features.
Posted by Anonymous on 2 November, 2003 - 6:30 pm
It's my strong recommendation that you do not follow an approach where you ask for the systems features, and try to developed your requirements around it, it would be extremely expansive and counter productive.
You should get your requirements listed clearly – preferably form your operation group and end users in particular- and insist that any PIMS supplier you select develop all the applications in as generic format as possible – such as MS Excel or Crystal Report – and provide all the interfaces to third party systems that you might need to connect too, and by far make sure that you supplier has excellent local support.
I strongly recommend that you look into a PIMS system supplied from your DCS vender as those have a tendency of being easy to install and the vender will be extra careful in making sure that the PIMS dose not cause any problem on the control network or increase the load on it.
I have managed 3 PIMS projects with different suppliers and all were comparable, and the engineering and configuration played the biggest role in making the project successful with the product selection playing a somewhat secondary role. The product that I have used are :
1) Honeywell PHD
2) OSI PI
3) Yokogawa ExaQuantom
Posted by Khalid on 26 September, 2012 - 4:56 am
We intend to use PIMS but due to lack of experience we may be shortchanged by the contractor into accpeting a simple historian. Would like to know how to differentiate between the two. And how useful would a PIMS be in a wastewater industry?
Posted by HR on 13 February, 2004 - 4:33 pm
In my experience the best is test before anything. Mainly must test the interface between DCS and the PIMS, if that interface doesn't load the dcs, you have advanced a 50%.
I recommend:
PI OSIsoft and
honeywell PhD
Q: Why did the tachyon cross the road?
A: Because it was on the other side.
Advertise here
Advertisement
our advertisers
