I have to connect to a facility separated from our main plant 7km aprox. We're still studying if it's better to connect two PLCs or a master PLC in plant with a remote ET200M (I prefer this one).
I've seen questions about wireless profibus before but I want to know if someone have tried one solution to do this before, because I've read that wireless profibus is not a good option and there's still no good technology to do this.
The connection speed we use is 187.5kbps.
Any help will be useful.
Julio
Julio
Would wireless ethernet be a better option? I don't know your situation so I am not going to suggest that it is, just pose the question.
Ethernet has been tried and proven and may be a better solution for wireless connectivity, especially if what you say is true
Mick
Mick
Token passing bus systems are a problem with half duplex radios. The Profibus must be slowed down to self defeating speeds to achieve acceptable target rotation times for the bus monitoring system. There are radios around that can do the job but they are horrifically expensive.
Use Ethernet communications with an 802.11G capable (NLOS) radio and you should be a happy chappy. Dlink makes a great industrial standard outdoor radio for aroung USD400
Donald Pittendrigh
Donald Pittendrigh
If you use PROFIbus-DP and there are no remote backup master stations, there is no token passing. PROFIbus-DP uses only master/slave communications protocol, not token passing, to transfer data. Token passing is used only to
transfer bus mastership, usually to a backup master.
Dick Caro
Richard H. Caro, CEO
CMC Associates
2 Beth Circle, Acton, MA 01720
Tel: +1.978.635.9449 Mobile: +1.978.764.4728
Fax: +1.978.246.1270
E-mail: RCaro@CMC.us
Web: http://www.CMC.us
Buy my new book: Automation Network Selection
http://www.isa.org/rd.cfm?id=3573
Dick Caro
CMC Associates
Apparently so, please explain the target rotation time concept which is applied to the monitoring of remote IO stations with a single master.
DP
DP
Donald, I can only assume that they are talking about the round-trip elapsed time between the Master's poll of the remote I/O station, and the completion of the data transfer requested by that poll. This is not token passing, although the Profibus specification still talks about "token rotation time" a similar phrase.
Dick Caro
Dick Caro
Precisely, and for that reason, let it be called token passing as everyone thinks they know what that means, and the end result amounts to the same thing.
Cheers Donald P
Cheers Donald P
Westermo from Sweden have a very nice product that alows a Profibus connection accros a Serial Link such as a Radio Modem. Check Out http://www.westermo.com/Resource.phx/content/products/fieldbus/adapter s/fd-10.htx
It means that once you have Profibus DP you can use your favourite Radio Modem to do the wirelss link.
Manny Romero
Paqworks Industrial Data Comms
Australia
info@paqworks.com
++61 2 9911 6670
Manny Romero
Australia
info@paqworks.com
++61 2 9911 6670
Try www.dataeagle.de
DATAEAGLE 2400 is a S7 - S7 Network by radio link up to 20km . The plc connection is done by MPI Interface.
Thomas
Thomas
> Information regarding Profibus over radio can be found at
> http://www.radiodata.co.uk/profibus
Link no longer works. I have the same requirement for the wireless connection.
Jerry
Jerry
Reason number 746 to change to ProfiNet.
You know you have a small apartment when Rice Krispies echo.
-- S. Rickly Christian
