R
[Editor's note: We are running this post because of its unique subject matter and potential interest to our forum users. Please refrain from posting similar pleas for help.]
Gentlemen!
I see there are many clever brains out there and therefore I am raising my plea to you for a control solution to our "plant": The plant is a so-called Rolling Road (chassis dynamometer). This is a means of performance testing a road car: the driving wheels are running in a roller set, which is usually embedded in the ground. This roller set can be "braked" using a so-called Eddy current brake (retarder), the type which is also used on heavy trucks/tractor units. I am struggling to get a really good controller working for this. The requirements are:
- minimal overshoot or no overshoot
- fast response
The roller set needs to be governed to run at a constant speed. A speed signal 0-5V is avialable. A load signal (how much the retarder is "braking" is also available as
0-5V).
As controller I have available:
MCU PIC 16F877
analog inputs to set GAIN, INTEGRAL, DERIVATIVE
analog inputs to sense speed, load
analog input to sense SETPOINT
I program the PIC in C (as I am not clever enough for Assembler )
I would like to try different control algorithms to fulfill my control needs. The person who priovides me with a solution which will find to work to my requirements I shall award 50 (fifty) US$. This I promise by my honour. This is only for solutions which work well!! For a poor
solution I have already (my own ...).
If you would kindly send me some algortihms (Basic would be fine) or C for me to try, that would be great. My e-mail is [email protected]. It will take me a while to try them out, but I shall keep you posted on this interesting project. This Rolling Road is for the means of performance tuning engines and we'll have Porsche, BMW, etc. on it. It
will be great It is important that the control ensures that the roller speed does not drift off, when the load (braking) is varied. The roller speed must be kept constant as best as possible.
Maybe a "Fuzzy" would be better? Whatever, I will try all possibilities using the PIC 16F877 MCU (8 analog inputs, 20MHz clock). The MCU control output is an analog signal,
by the way (digital outputs load a DAC with the output control signal).
Gentlemen, many thanks for your valued help. Ladies, also invited, of course!
Many thanks !! )
Rudi
P.S. example: if the setpoint was to be 50mph, I would like the rollers to run freely with no braking on at all until maybe 45mph, then the brake should be activated so that there will only be a minimal overshoot of say 10 percent (55mph) and a fast settling. Also, a "learning"
controller... Fuzzy? would be a good idea... what do you think?
Gentlemen!
- fast response
0-5V).
MCU PIC 16F877
Many thanks !! )
Rudi
