I need to measure the mass flow rate of oxygen in a small pipe. Tests are run through this pipe for 7 seconds, and the supply pressure changes every time. The supply pressure ranges from around 40-100 psig. It is in comp flow. Without spending the big bucks on a flowmeter, does anyone have any suggestions for me?
Thanks,
Josh
Thanks,
Josh
