I have some background in PLC programming but I am a begginer with Siemens. I have 2 S7 315-2D. I want to connect them on a Profibus (One master one slave).
My first problem is that I can't make the configuration write. Either BF led (Bus failure) is flashing or BF is off but program goes to Stop when try to run it (OB1 only has the simplest network one input makes one output).
Second what functions can I use to exchange data between the 2 CPU's?
Thanks a lot!!!
Thanks a lot!!!
