R
We have a boiler plant and steam is generated at following conditions:
Meter Max Flow: 125 TPH
Meter Min Flow: 0 TPH
Steam Transmitter DP range: 0 - 3500mmWC
(i.e., 0 - 3500mmWc corresponds to 0 - 125TPH)
Operating Pressure: 10.5KG/CM2
Operating Temp.: 180-182 Degrees centigrade
Orifice's Beta value: 0.663339756
Viscosity of steam: 0.00015850 Poise
Pipe size: 406.4/381.0 (OD in mm/ID in mm)
Based on this data, would anyone suggest the exact formula for compensation of steam flow? Also can anyone suggest a suitable link on net for downloading steam parameters esp. density of steam at various temperatures?
thanks
au revoir
Rahul
thanks
au revoir
Rahul
