Galvanic isolation
Local and wide area networking in factory automation. topic
Posted by Habs on 2 December, 2004 - 6:59 pm
Just a question with regards to galvanic isolation. I don't understand what it is, is it a some galvanised metal put in between the network, or is it a resistor network? I am trying to eliminate an AC voltage in my RS485 line.
Posted by Heinz-Juergen Oertel on 3 December, 2004 - 7:39 pm
http://www.rs485.com/pfaq.html#GalvanicAnchor
with best regards / mit freundlichen Grüßen
Heinz-Jürgen Oertel
+==================================================================| Heinz-Jürgen Oertel port GmbH http://www.port.de
| mailto:service@port.de
| phone +49 345 77755-0 fax +49 345 77755-20
| Regensburger Str. 7b, D-06132 Halle/Saale, Germany
| CAN Wiki http://www.CAN-Wiki.info/
| Newsletter: http://www.port.de/engl/company/content/abo_form.html
Posted by Sivakumar on 23 August, 2005 - 2:07 pm
Galvonic Isolation - forced isolation between the two circuitry, Transfer of energy between the two circuitry without direct flow of current.
eg. Opto coupler , Isolation transformer
Isolating the primary and secondary circuits for acheiving common mode attenuation.
Secondary circuit in no way will be affected by the implications created on the primary circuits by the external factors
Posted by Henri on 3 December, 2004 - 9:03 pm
It means an isolation between 2 circuits, i.e. no metal conduction between those circuits. Transfer will then take place for instance optical or by induction (magnetic).
Think of your mains transformer, if you take an Ohmmeter, and try to measure the resistance between the primary and secundary windings, you find a very high to indefinite value, if this is a good transformer though.
So isolation is the word, Galvano is one of the guys in the 18th century whom did a lot of research in that area, like Ohm and Volta.
Hope this simple explanation will help you.
Henri
Posted by Dick Caro on 3 December, 2004 - 9:10 pm
It's not too complicated. Galvanic means "related to direct-current electricity" or DC. Galvanic Isolation says that the circuit is separated from the signal source (or sink) in such a way that DC current cannot bridge the connection. There are two generally accepted methods for galvanic isolation: use of transformers or use of optical isolators. Both allow the AC component of a signal to pass, but not the DC component.
Your network signal appears as AC on RS 485. I believe you don't want to use Galvanic Isolation. You need to pass low voltage AC but block high voltage AC. Intrinsic safety barriers for RS485 will do this. They use a Zener diode that will shunt any high AC voltages to ground, should they occur, along with the signal. If you always have high voltage AC present, you have more problems than we can
discuss here.
Dick Caro
Richard H. Caro, CEO
CMC Associates
2 Beth Circle, Acton, MA 01720
Tel: +1.978.635.9449 Mobile: +.978.764.4728
Fax: +1.978.246.1270
E-mail: RCaro@CMC.us <mailto:RCaro@CMC.us>
Web: http://www.CMC.us
Buy my books: Automation Network Selection
Wireless Networks for Industrial Automation
The Consumer's Guide to Fieldbus Network Equipment
for Process Control
http://www.isa.org/books
Posted by Steve Myres on 3 December, 2004 - 9:18 pm
First, "isolation" refers to two circuits which are not connected electrically, with no conductivity between them. Now the problem arises when we must use information from one circuit in the other while maintaining the isolation. One way is by using light produced in one circuit and sensed in the other; thus you will find the phrase "optical isolation". Another way is to pass the two circuits through the primary and secondary of a transformer; this is "galvanic" isolation, so "galvanic" just refers to the specific means of transmitting information between electrically independent circuits.
Steve Myres, PE
Automation Solutions
(480) 813-1145
Posted by Carla on 25 June, 2005 - 5:43 pm
Is GI an effective method of control for Electro Static Discharge?
Posted by Curt Wuollet on 27 June, 2005 - 9:32 am
Not by itself, no. In fact, isolating circuits can make them more vulnerable to ESD in certain circumstances. Grounding, shielding and dissipation are tools for ESD control. And there are few simple answers.
cww
Posted by Meir Saggie on 5 December, 2004 - 11:29 am
Galvanic isolation means that there is not conductive (usually metallic) connection between two circuits. It is usually achieved by optocouplers. In your case, the two sites connected by the RS485 link have different (and
probably bad) grounding.
Meir
The trouble with a kitten is that
When it grows up, it's always a cat
-- Ogden Nash.
Advertise here
Advertisement
our advertisers
