member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
The District of Columbia has a law forbidding you to exert pressure on
a balloon and thereby cause a whistling sound on the streets.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
interfacing RS232 in WinXP using VC++
Programming languages. topic
Posted by maheshkg on 23 February, 2005 - 7:56 pm
I have problems in interfacing RS232 in VC++ in WinXP. Please help me with some sample code in VC++. Please reply to me at manu_kalose@yahoo.co.in
Posted by Gildas Trebaol on 7 March, 2005 - 5:57 pm
If you are still looking for some code to read or write the RS232 COM port, here is a utility that I used in november 2004 for controlling ADAM/NuDAM DAQ modules. The code is developed for Win32, OS-9 and Unix, but I have not tested it on Unix yet (it works on Win32 and OS-9.
You can get it at:
http://gtrebaol.free.fr/rs232_rs485/tty.zip
If you improve it or find some bugs, please send me your updates.
Best regards,
Gildas
NB:
I tested the RTS_CONTROL_TOGGLE mode with RS485 devices, and I noticed that Windows has a significant delay between the end of transmission and the control of the RTS line,
so this mode does not work properly with a RS485 equipment that replies "too fast" for Windows, due to a conflict between the RS422 amplifiers simultaneously active on the RS485 line.
Posted by Theo on 12 September, 2005 - 9:43 pm
Hello Gildas,
I was looking for a RS485 sample code and I found yours. It is a great work!!! But, I am working under win2k Pro using visual C++ 6.0 and it does not compile at the first try. In your sources files there is no OS protection. I have added what I need to run it under win2k and it works now; so good job you have done.
My question:
Is this an RS485 interface? (just to be sure!) Is this for a specific device? (I have seen specials commands <<strcpy( buf, "$28MDB" );>> and others). What can I do or modify to use it for an other device?
Thank you in advance for your help.
Theo
Posted by Kunal Lagwankar on 7 April, 2005 - 1:27 pm
Hello
If you are still looking for a sample code, look below.
#include <windows.h>
#include <stdio.h>
#include "globs.h"
void InitCommPort(void)
DCB dcb;
char *pcCommPort = "COM1";
COMMCONFIG CC;
DWORD dwSize;
COMMTIMEOUTS timeout;
extern HANDLE hCom;
extern int eflag;
hCom = CreateFile( pcCommPort,GENERIC_READ | GENERIC_WRITE,0,NULL,OPEN_EXISTING,0,NULL);
if(!GetCommState(hCom,&dcb))
printf("\nGetCommState failed with error %d\n",GetLastError());
eflag = -2;
else
dcb.BaudRate = CBR_9600; // set the baud rate
dcb.ByteSize = 8;
dcb.Parity = NOPARITY; // no parity bit
dcb.StopBits = ONESTOPBIT; // one stop bit
GetCommConfig(hCom,&CC,&dwSize);
CC.dcb = dcb;
SetCommConfig(hCom,&CC,dwSize);
GetCommTimeouts(hCom,&timeout);
timeout.ReadIntervalTimeout = 0;
timeout.ReadTotalTimeoutConstant = 500;
timeout.ReadTotalTimeoutMultiplier = 0;
timeout.WriteTotalTimeoutConstant = 0;
timeout.WriteTotalTimeoutMultiplier = 10;
if(!SetCommTimeouts(hCom,&timeout))
printf("\nError setting timeout %d\n",GetLastError());
eflag = -1 ;
int AnalogPoll(unsigned char *Xbuffer, unsigned char *Rbuffer)
short retry =0;
DWORD BytesWritten, BytesRead, n;
extern RTU Meter[TERMINALS];
extern HANDLE hCom;
extern int eflag;
unsigned register i;
while( (!WriteFile(hCom,Xbuffer,8,&BytesWritten,NULL)) & (retry < 2) )
retry++;
if ( (retry == 3) || (BytesWritten != 8) )
printf("\nWrite to Meter %d failed with %d\n",Meter[0].Request.SlavAddr,GetLastError());
eflag = -1;
return -1;
else
printf("\nTransmitted data = ");
for(i=0;i<8;i++)
printf("\t%2X",Xbuffer[i]);
n = Meter[0].Request.ReadCount*2 + 5;
retry = 0;
while( (!ReadFile(hCom,Rbuffer,n,&BytesRead,NULL)) & (retry < 2) )
retry++;
if ( (retry == 3) || (BytesRead != n) )
printf("\nRead Error %d !\n",GetLastError());
eflag = -1;
return -1;
else
printf("\nData Read = ");
for(i=0;i<BytesRead;i++)
printf("\t%2X",Rbuffer[i]);
return 0;
Posted by vikrant on 20 May, 2005 - 4:55 pm
dear friends i want some help from you. i am working on RFID project. i want to develop such software that RFID reader send some data to serial port of pc continously. this is done by RS232 cable. do u have any source code in c/c++/vc++ or which tool i use, also language so that i can achieve it. please send me mail or reply.
thanking you
vikrant
Posted by Joel on 9 November, 2006 - 11:56 pm
i have the same problem as vikrant im also working on a RFID project that requires my reader to send data to my PC through the serial port with the use of RS232. could someone please help me in finding any source code in c/c++/vc++/java or which tool i use, also language so that i can achieve it. please send me mail or reply.
Joel
Posted by may on 19 September, 2007 - 11:17 pm
I also have a same problem with what you have mentioned about RFID project. If you've already got that program codes, can share with me?
Thanks & regards,
may
Posted by Shrividya on 23 June, 2009 - 5:33 am
Can you help me to read the RS232 Comport data using VC++6.0
Ms. Shrividya
Posted by anis on 18 June, 2005 - 12:34 am
kann you write please the bib "globs.h" i need it.
thx
Posted by Anonymous on 5 July, 2005 - 6:26 pm
I'm working on the RS232 connection to Vc++ now, i need to connect them without using MScomm. So, any other functions or classes that support this?
And I need the code for #include "globs.h" too...
Can you please send me? Thanks!
Posted by Anonymous on 20 May, 2005 - 5:11 pm
hi,
i have a problem to compile your code source in a platform Windows NT so i have all time an error message indicate a link problem
est_tty.obj : error LNK2001: unresolved external symbol __imp__timeGetTime@0
Debug/test_tty.exe : fatal error LNK1120: 1 unresolved externals
a_chemssou80@yahoo.fr
I will be to you t-pieces recognizing
Posted by Anonymous on 28 July, 2005 - 11:15 pm
would u give me ur result of ur problem?
Posted by Anonymous on 8 September, 2006 - 10:23 pm
I have the same problem so send me the sample code and other comments regarding RS232 interface in vc++
Advertisement
