We are looking to put a 24V DC brushless on a chemical metering pump for use in a hazardous environment. It has to be rated UL or CSA for Class 1, Division 1. I have contacted most if not all of the major manufacturers without success. A PWM drive rated for use in a Class 1, Division 2, Groups C & D is also needed. Any help in this department would be very much appreciated.
Thanks,
Len
Thanks,
Len
It appears that we may have found a motor that will work for us. We are still working out some of the technicalities. What application are you looking to put these motors in?
I am trying to transfer some methanol we have a little gear pump but need a small low speed 24VDC motor for a class 1 div 1 area. we want to run it off the SCADA batteries. just started looking...not having much luck. do u mind me asking who was able to help you. I'm contacting Bodine tomorrow.
How much Methanol do you have to transfer?
I recently finished a Methanol project where we installed underground tanks using the same type of submersible pump used in a gas station.
These pumps are single phase 220V centrifugal, quite cheap and have all the approvals required.
Roy
Roy
Since it's a small motor could you install a regular motor inside a Nema 7 enclosure.
Man is the only animal that can remain on friendly terms with the
victims he intends to eat until he eats them.
-- Samuel Butler
