member
passwd
remember me on this computer.
- join now -
Select a topic of interest:
...and press:
My mother wants grandchildren, so I said, "Mom, go for it!"
-- Sue Murphy
www.control.com/rss
Select a Page Style
- BluFu
- Classic
(cookies required)
from the electrical department...
TSXPCX1031cable for RS485 connection to port1 of twido
Networking topic
Posted by Anonymous on 1 June, 2005 - 6:46 pm
I need to communicate a Twido PLC with a PC using modbus. I was thinking on a RS485 serial communication.
1) if the PC does not have an RS485 port. Can I use the programming cable TSXPCX1031 as RS232=>RS485 converter?
2) Twido documentation says that pin 5 must be connected to com, pin 7. The programming cable TSXPCX1031 has a mini-din connector, can it be used to convert RS232 to RS485,
Posted by Anonymous on 2 June, 2005 - 11:40 pm
I think the programming cable as converter is ok. You can try it. It's Ok.
Posted by Nebojsa Lazarevic on 17 June, 2005 - 10:44 am
Yes, it works, but I have another MODBUS problem.
When I try to read 40001 adress throw modbus serial driver (iFix MB1 driver, Modbus tester from www.modbus.pl, or somthing else) ALWAYS GET RESPOND LIKE ILLEGAL DATA ADDRESS. Where is problem? In Twido modbus implementation or?
I just want to connect Twido to Scada.
Nebojsa Lazarevic, Scada & Automation eng.,
Umbra Software
nebojsal@umbra.co.yu
Posted by Marco on 28 September, 2005 - 10:41 pm
Hi, i am looking for the pinout of tsxpcx1031, in order to make a communication system between the Twido and a PC across G.703, please help me if you can.
Posted by Anonymous on 7 March, 2008 - 6:24 pm
I have connected a Twido to a SCADA.
This is how I did it:
When you program the Twido, you will notice that there is a program running in your notification bar. This program acts as a Modbus Ethernet to Modbus RTU gateway.
So, from the SCADA you can scan to this gateway using modbus Ethernet.
Whats nice about this is you can program and scan to the Twido AT THE SAME time through the cable.
I can't remember on what port you should connect locally (ethernet) though... just use the same port the programming softwre is using. (You can use a port monitor to figure out what port it is using.)
Posted by Sebastian on 3 June, 2005 - 12:23 am
> RS232=>RS485 converter? <
Yes.
> used to convert RS232 to RS485, >
You must use switch setting 3
"Other direct"
Posted by Andrzej on 3 June, 2005 - 12:26 am
If you want use the cable for modbus communication the pin 5 and 7 must be connected, for programing the pins must be disconnected. The pin connection is realized by the switch Ter direct/Other direct.
Andrzej
www.modbus.pl
Posted by Alastair on 3 June, 2005 - 12:32 am
The TSXPCX1031 cable is the specified serial programming lead for the Twido PLC. You must turn the switch on the cable to position 2 for programming. The Twido uses Modbus as it's native communications protocol. You may have to use Twidosoft to configure Port 1 with the appropriate settings (Modbus, addr 1, 9600,8,E,1) if you are using a different adapter to access the Twido.
Posted by Anonymous on 3 June, 2005 - 8:29 pm
Yes it is possible. You have to select position 3 in PCX1031. Programming is using position 2. Ofcourse port parameter have to set correctly. By default it is remotelink.
Posted by Anonymous on 3 June, 2005 - 8:34 pm
Answer to 1) Yes, You can, and You must try with the cable selector converter (position 0,1,2,3)
Answer to 2) I think so, because the documentation refers to the port TER of twido.
Advertisement
