Hello experts,
I want to connect RS232 port using java to interface with micro-controller (8051). Can anyone help me to know the coding to initialise the scope and configure the RS232 in java?
Here are some links that may help
http://java.sun.com/products/javacomm/index.jsp
http://www.google.com/search?q=RS232+in+java&hl=en&lr=& start=10&sa=N
You're going to need to install the Java Communications API in order to interface with RS232. You can download it and read the documentation at Sun's website here:
Here is an article on how to use it:
http://www.javaworld.com/javaworld/jw-05-1998/jw-05-javadev.html
Good luck, Carl
Good luck, Carl
i was wondering, is it also applicable even if i use other micro controller?
Does the Java Communications API work in windows XP?
Look at http://www.giovynet.com, you will find FREE java libraries to manage serial port...
I've found great tutorial for RS232 with Java programming that shows how to use RXTX library in practice:
http://www.kuligowski.pl/java/rs232-in-java-for-windows,1
BR
Mark Cleav
BR
Mark Cleav
Fuch's Warning:
If you actually look like your passport photo, you aren't well
enough to travel.
