When we use DP Transmitter for measuring drum level, why we install condensate pot in the line from the upper tapping. Which line should be connected to H and which line to L of the DP transmitter
| Thread starter | Similar threads | Forum | Replies | Date |
critical level measurement issue in a reflux drum application under high temperature and pressure | Process Control | 0 | |
| R | Level Transmitter on Condensate Drum | Sensors & Calibration | 3 | |
| N | Drum Level DP Transmitter Connection | Power Generation | 1 | |
| S | DRUM LEVEL TRANSMITTER | Process Control | 2 | |
| N | Drum level Transmitter | Process Control | 6 |
