Do the three signals from <R>,<S>&<T> processors to three coils MOOG fuel servo-valve have the same polarity? Because we tried to start our GE Frame 5 MKV HMI gas turbine but it failed to ignite and after reversing the polarity of processor<R> to servo-valve signal, the unit succeded to reach FSNL. What I have mentioned above is the only thing which brought the unit to FSNL after more than twenty failed attembts and after changing approximitly all fuel oil system components(main fuel pump, servo-valve, by-pass valve, clutch, flow-divider and all the ten check valves of combustion chambers).
