Jump to a Date
Twitter Feed
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
As the poet said, "Only God can make a tree" -- probably because it's
so hard to figure out how to get the bark on.
-- Woody Allen
-- Woody Allen
www.control.com/rss/
I'm looking into implementing Modbus function
code 8, sub function Code 00.
The Modbus Application Protocol Spec V1.1a shows the Data section of the message to be N x 2 bytes in size, yet the message does not contain any additional byte count information. This may be ok for Serial ASCII which wraps each message in special characters (':"<message>"\n") but Serial RTU does not. It is unclear to me how a
Modbus Slave could determine the end of such a message.
Does anyone have any input on this? could this be a typo in the spec? All additional function code 8 sub function codes show fixed size (two
byte) Data sections.
Thanks.
Thanks.
FYI: Many devices do not support this function in either master or slave mode.
Each subfunction has it's own special definition for the packet.
From the book:
"Most of the diagnostic queries use a *two–byte* data field to send diagnostic data or control information to the slave."
Function 8, sub function 0000 only has a fixed length, 2 bytes long, data field. Therefore there is no need to send 'N' and it should be easy to determine the end of the packet.
FYI: One of the methods used to determine the end of the packet is to use the packet timeout which is typically 3.5t (byte-time) (and a fixed time for fast baud rates).
-Max
From the book:
-Max
In Modbus RTU the interval of at least 3.5 character times marks the end of the message. A new message can begin after this interval.
Andrzej
www.modbus.pl
Andrzej
www.modbus.pl
A more complete discussion here:
http://groups.google.com/group/NModbus-discuss/browse_thr ead/thread/d642162d5f68a36c
Related articles from Control
Engineering magazine- Free webinar on Zigbee for embedded systems
- WirelessHART compliance verification receiver available
- PTO reports high growth, cross-industry collaboration
- Wireless helps Hexion with smoke detection, control room reporting
- Wireless networks for water and wastewater plant: easy, timely info access
- Chemical company processes critical data via wireless Ethernet
- Enclosures: Improve NEMA designs, enclose wireless equipment, keep cabinets cool
- New products: Supporting wireless communications at every level
- NIWeek: National Instruments targets WiFi, Ethernet, adds LabVIEW 8.6
Subject to its Terms of Use.
