- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
www.control.com/rss
txs
Turning gear must be engaged when the steam turbine speed drops to 0 RPM. Usually the turning gear motor will run at about 20-30 RPM and the clutch will engaged when the speed reaches 0 RPM. In case the turning gear failed to engaged after reaching zero speed, quick action needs to be taken to ensure that it is engaged. If all the measures fail, manual barring should be done immediately (seriously, it's damn hard. ;) ).
However, worst case scenario, should everything fail, the turbine should be put into standstill for a period of at least 3 days (usually) until the wheel space temp reaches nominal value (avoid uneven cooling).
Bear in mind that rolling the turbine during this kind of situation will cause serious rotor bow condition.
P.S.: Maybe the originator's machine has some level of rotor bow already, which is causing the high vibration. ;)
- PTO reports high growth, cross-industry collaboration
- New, efficient industrial gas turbines coming
- Wireless helps Hexion with smoke detection, control room reporting
- Wireless networks for water and wastewater plant: easy, timely info access
- What process control applications are OK for wireless?
- Chemical company processes critical data via wireless Ethernet
- Enclosures: Improve NEMA designs, enclose wireless equipment, keep cabinets cool
- Affiliate integration: Advanced Automation, IAEF and EIAL become Avanceon
- Product experience: Who leads in 2008 with automation system integrators?
- Controller platform: Small-scale system bridges device gap
