Write_reg Programming Example
David
I need programming example for Quantum to Quantum write_reg command. I have used ladder to attempt a transfer of 5 registers from one Quantum to another using the Ethernet modules. I have used the book to fill in the parameters, but it does not work. Does somebody have an example of the ladder to use to have a 434-12A write 5 registers to another 434-12A, over ethernet??
Use the I/O Scanner of the Ethernet cards is the simplest. Modbus ports can be used with Peercop.
No ladder is needed for ether.
