P
Does Intools ver6.0 give a proper solution for an AS-i system's documentation? It seems to get a correct representaion of a system a mix between conventional and fieldbus I/O is necessary, although the implementations is different. It also seems that somewhere along the line the link beween the PLC/DCS and field IO can only be represented in a manual way?
