Rockwell is still promoting the ProcessLogix?
shn
Does anyone know if Rockwell is still promoting the ProcessLogix? I went to the Rockwell website, but found you had to dig a bit to find any information on it. Found lots of stuff on Control Logix and Soft Logix.
No. They figured out they had a better solution without it.
ProcessLogix is Honeywell's software running on Rockwell hardware. The equivalent would be Honeywell's Experion with C200 controllers.
You can upgrage your ProcessLogix system to Experion PKS, without throwing away your controllers, graphics, programming, reports, or any intellectual property. This is much cheaper and easier than replacing the PLX52 with a PLC. Contact me at this e-mail address if you need more information: [email protected]
Mr James
Could you tell me if we have Controllogix chasis and we changed the processor using C200 family, Will it work without problems inside Experion PKS R210 environment?
I'm asking because my company will purchase ControlLogix Training workstation. Also they want to purchase Experion R210 with C200 to use in the same training center to be a good training tool for the DCS & PLC Maintenance engineers.If there is any method to purchase few Honeywell hardware cards to convert controlLogix to act as C200 system It may save some money.
