I am woking with Trident PLC. The RJ45 ports in the MP baseplate support only TSAA protocol (which is used for tri-stn application). I also have some other application in my PC which runs on TCP/IP protocol. So I am in trouble.
Can anyone help me out?? Is there any TSAA to TCP/IP converter in the form of Ethernet Switch, etc.?
The Trident MP only supports TriStation 1131. It does not support TSAA, which is an open source application for which you can write your own drivers. Use a Trident CM, it supports TCP/IP via RJ 45, MAU and AUI.
The average income of the modern teenager is about 2 a.m.
