member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
"By the time they had diminished from 50 to 8, the other dwarves began
to suspect 'Hungry' ..."
-- Gary Larson, "The Far Side"
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
Convert humidity to wet bulb
Posted by Anonymous on 20 April, 2007 - 1:23 am
I need help to convert humidity to wet bulb temp in the PLC. Is there a formula for this conversion?
Thanks.
Posted by Phil Corso, PE on 21 April, 2007 - 10:58 am
Anonymous...
If you are refering to Specific Humidity of Air (Humidity Ratio) I have a Nomogram that can help. Send me your address and I will send it to you!
Regards, Phil Corso, PE (Cepsicon@aol.com)
Posted by Wm.C.Corwin on 11 April, 2008 - 4:59 pm
For the benefit of robotic webcrawlers harvesting email addresses, the at symbol is replaced by a unicode happy face: ☺
cc:
Cepsicon☺aol.com
nyrath☺projectrho.com
Title: Water Vapor Calculations
I put this letter on the
http://www.control.com/thread/1026234127
http://www.control. com/thread/1026234618
http://www.control.com/thread/1026157279
foru m.
I put the Bill Sisson, Nipak, Inc. Pryor, OK,
and F. Caplan, Power's Data Sheet, Oakland CA,
charts online at
http://www.issi1.com/corwin/calculator/Sisson_specific.pdf
ht tp://www.issi1.com/corwin/calculator/Sisson_absolute.pdf
http://www.is si1.com/corwin/calculator/Caplan_density.pdf
http://www.issi1.com/corw in/calculator/Caplan_dew.pdf
and linked to them from
http://www.ConcurrentInverse.com
http://www.issi1.com/c orwin/calculator/vapor.html
which in return is linked to from
http://en.wikipedia.org/wiki/Psychrometrics .
It might be better to have the journal name, date and page number for the references. Someday I might make nomograms digitally in the .svg format so that they can be scaled up to achieve any precision desired.
I don't know the best way to do every calculation
but the more references there are the more ways
will be available to check the calculations.
ref:
Phil Corso
id=1026234127
nomogram collection of Cepsicon@aol.com
forum at control.com
Sisson_specific.pdf 0727-1 Specific Humidity.PDF
Bill Sisson, Pryor Oklahoma
nomogram and BASIC microcomputer program determine specific humidity of air
Sisson_absolute.pdf 0727-2 Vol Wtr vs Twb Tdb .PDF
Bill Sisson, superintendent of Operations, Nipak, Inc. Pryor, OK
Oil, Gas & Petrochem Equipment March 1978
Nomogram determines volume percent of water in air
Caplan_density.pdf 0727-3 Moist-Dry Air Density.PDF
F. Caplan, Oakland CA
Calculate density of moist or dry air Power's Data Sheet
Caplan_dew.pdf 0727-4 Compressed Dew-Pt.PDF
Calculate dew point and water content of compressed air Power's Data Sheet
http://www.projectrho.com/nomogram/compound.html#familysc ale
Internet Explorer 6.0 Fix
Advertisement
