Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
"What's the use of a good quotation if you can't change it?"
-- The Doctor
-- The Doctor
www.control.com/rss/
It's my first time when I'm working with Twido PLC, and I have a very strage problem.
Let's say I have such rung:
| I0.0 I0.1 Q0.0 |
When both inputs are active the output doesn't get active.
Maybe anyone else had this problem and knows how to solve it?
Example:<br>
http://img153.imageshack.us/img153/19 03/twidobj5.jpg
Thanks in advance.
Please check if you have used the same output in any other part of your logic.
yes i did and that was a problem if you use coil with same address more then once it does't work like it should...
Pls make a note of Serial number of Twido you are using and check with schneider support team, You might require a patch as some cpu version had a problem
I know this is a stupid question, but are you sure you put the Twido into run mode?
Check to see if the output (Q0.0 and %M41 in your two examples) is also addressed anywhere else in the program. There might be another rung turning the same output off.
Is your configuration correct? If you don't have the hardware configuration correct, the output will not function.
Check the hardware configuration. If it is incorrect, the outputs will not function.
You probably have some Set or Reset instructions using that output. Donīt mix coils and memorized actions.
Take care
Take care
When two inputs is high then there should be output. If not, there are two possibilities:
1. Maybe anywhere line is deleted in between output & input
2. Twido PLC may be in stop mode
With regards,
Pradeep
With regards,
Pradeep
Related articles from Control
Engineering magazine- Siemens announces motors, drives, and motion control advances
- ODVA announces new editions of CIP network specifications and testing of Ethernet/IP products
- Molex releases new connection system and expanded line of Ethernet switches
- Wurldtech Achilles cyber security testing
- OMAC guidelines ease design, programming, integration
- Webcast to examine best practices for adopting Microsoft Windows Vista
- Vision sensor inspects for defects at any part position, rotation
- Smart vision sensor features simple setup, high-speed inspection
- Cameras with DSP coprocessors offer multiple options
- GHS has EAL6+ operating system security certification; launches Integrity Global Security
Subject to its Terms of Use.
