Cicode
F
frazes
<p>I have written a cicode to pass information to SQL but wrong information has been passed into the field in the SQL table. My data is also processed in the wrong line. For e.g., peanut biscuit run in chocolate line.
<pre>
GLOBAL STRING Line1_BatchID
GLOBAL STRING Line1_CompletedDate
GLOBAL INT Line1_CompletedQty
GLOBAL STRING Line1_CompletedTime
GLOBAL STRING Line1_ExpiryDate
GLOBAL INT Line1_Qty
GLOBAL STRING Line1_OrderID
GLOBAL INT Line1_BatchID_ID
GLOBAL INT Line1_CompletedDate_ID
GLOBAL INT Line1_CompletedQty_ID
GLOBAL INT Line1_CompletedTime_ID
GLOBAL INT Line1_ExpiryDate_ID
GLOBAL INT Line1_OrderStatus_ID
GLOBAL STRING Line2_BatchID
GLOBAL STRING Line2_CompletedDate
GLOBAL INT Line2_CompletedQty
GLOBAL STRING Line2_CompletedTime
GLOBAL STRING Line2_ExpiryDate
GLOBAL STRING Line2_OrderStatus
GLOBAL INT Line2_Qty
GLOBAL STRING Line2_OrderID
GLOBAL INT Line2_BatchID_ID
GLOBAL INT Line2_CompletedDate_ID
GLOBAL INT Line2_CompletedQty_ID
GLOBAL INT Line2_CompletedTime_ID
GLOBAL INT Line2_ExpiryDate_ID
GLOBAL INT Line2_OrderStatus_ID
GLOBAL STRING Line3_BatchID
GLOBAL STRING Line3_CompletedDate
GLOBAL INT Line3_CompletedQty
GLOBAL STRING Line3_CompletedTime
GLOBAL STRING Line3_ExpiryDate
GLOBAL STRING Line3_OrderStatus
GLOBAL INT Line3_Qty
GLOBAL STRING Line3_OrderID
GLOBAL INT Line3_BatchID_ID
GLOBAL INT Line3_CompletedDate_ID
GLOBAL INT Line3_CompletedQty_ID
GLOBAL INT Line3_CompletedTime_ID
GLOBAL INT Line3_ExpiryDate_ID
GLOBAL INT Line3_OrderStatus_ID
GLOBAL STRING result
GLOBAL STRING result2
FUNCTION getOrderDetail(STRING Product_ID)
INT counter = 0
INT statusSQL, sqlResult;
STRING Sql1
STRING Sql2
STRING Sql3
result = ""
statusSQL = SQLConnect("DSN=SQLSRV_TBLS;SRVR=localhost;DB=FYPJ Integration of SAP NetweaverData;UID=labuser;PWD=success;");
IF statusSQL <> -1 THEN //If Connection Success
Sql1 = "SELECT SetId FROM ProductionDataField WHERE (Field = 'productid') AND (DataValue = '" + Product_ID + "')"
sqlResult = SQLExec(statusSQL, Sql1);
IF sqlResult = 0 THEN //If SQL Success
WHILE SQLNext(statusSQL) = 0 DO
IF result <> "" THEN
result = result + ","
END
result = result + SQLGetField(statusSQL, "SetId")
END
END
Sql2 = "SELECT SetId FROM ProductionDataField WHERE (Field = 'order status') AND (DataValue = 'pending') AND (SetId IN (" + result + ")) Order by SetID"
sqlResult = SQLExec(statusSQL, Sql2);
result = ""
IF SQLNext(statusSQL) = 0 THEN
//Select first SetId
result = SQLGetField(statusSQL, "SetId")
END
END
Sql3 = "SELECT Id, DataValue FROM ProductionDataField WHERE (SetId IN (" + result + ")) and (IsActive = 1) Order by field"
sqlResult = SQLExec(statusSQL, Sql3);
IF Product_ID = "Biscuit" THEN
IF counter < 9 THEN
IF counter = 0 THEN
Line1_BatchID_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 1 THEN
Line1_CompletedDate_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 2 THEN
Line1_CompletedQty_ID = SQLGetField(statusSQL , "ID")
Line1_CompletedQty = SQLGetField(statusSQL , "DataValue")
END
IF counter = 3 THEN
Line1_CompletedTime_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 4 THEN
Line1_ExpiryDate_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 5 THEN
Line1_OrderStatus_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 6 THEN
Line1_OrderID = SQLGetField(statusSQL , "DataValue")
END
IF counter = 7 THEN
END
IF counter = 8 THEN
Line1_Qty = SQLGetField(statusSQL , "DataValue")
END
END
END
IF Product_ID = "ChocolateBiscuit" THEN
IF counter = 0 THEN
Line2_BatchID_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 1 THEN
Line2_CompletedDate_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 2 THEN
Line2_CompletedQty_ID = SQLGetField(statusSQL , "ID")
Line2_CompletedQty = SQLGetField(statusSQL , "DataValue")
END
IF counter = 3 THEN
Line2_CompletedTime_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 4 THEN
Line2_ExpiryDate_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 5 THEN
Line2_OrderStatus_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 6 THEN
Line2_OrderID = SQLGetField(statusSQL , "DataValue")
END
IF counter = 7 THEN
END
IF counter = 8 THEN
Line2_Qty = SQLGetField(statusSQL , "DataValue")
END
END
IF Product_ID = "PeanutButterBiscuit" THEN
IF counter = 0 THEN
Line3_BatchID_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 1 THEN
Line3_CompletedDate_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 2 THEN
Line3_CompletedQty_ID = SQLGetField(statusSQL , "ID")
Line3_CompletedQty = SQLGetField(statusSQL , "DataValue")
END
IF counter = 3 THEN
Line3_CompletedTime_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 4 THEN
Line3_ExpiryDate_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 5 THEN
Line3_OrderStatus_ID = SQLGetField(statusSQL , "ID")
END
IF counter = 6 THEN
Line3_OrderID = SQLGetField(statusSQL , "DataValue")
END
IF counter = 7 THEN
END
IF counter = 8 THEN
Line3_Qty = SQLGetField(statusSQL , "DataValue")
END
END
counter = counter + 1
END
END
END
SQLEnd(statusSQL)
SQLDisconnect("DSN=SQLSRV_TBLS")
END
FUNCTION UpdateBatchID(STRING Product_ID)
STRING Sql1
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line1_BatchID + "' WHERE [Id] = " + IntToStr(Line1_BatchID_ID)
END
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line2_BatchID + "' WHERE [Id] = " + IntToStr(Line2_BatchID_ID)
END
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line3_BatchID + "' WHERE [Id] = " + IntToStr(Line3_BatchID_ID)
END
END
SQLEnd(statusSQL)
END
FUNCTION UpdateCompletedQty(STRING Product_ID)
STRING Sql1
Sql1 = "UPDATE ProductionDataField SET DataValue = '" + IntToStr(Line1_CompletedQty) + "' WHERE [Id] = " + IntToStr(Line1_CompletedQty_ID)
END
Sql1 = "UPDATE ProductionDataField SET DataValue = '" + IntToStr(Line2_CompletedQty) + "' WHERE [Id] = " + IntToStr(Line2_CompletedQty_ID)
END
Sql1 = "UPDATE ProductionDataField SET DataValue = '" + IntToStr(Line3_CompletedQty) + "' WHERE [Id] = " + IntToStr(Line3_CompletedQty_ID)
END
END
SQLEnd(statusSQL)
END
FUNCTION UpdateCompletedOrder(STRING Product_ID)
STRING Sql1
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line1_CompletedDate + "' WHERE [Id] = " + IntToStr(Line1_CompletedDate_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line1_CompletedTime + "' WHERE [Id] = " + IntToStr(Line1_CompletedTime_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line1_ExpiryDate + "' WHERE [Id] = " + IntToStr(Line1_ExpiryDate_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = 'Completed' WHERE [Id] = " + IntToStr(Line1_OrderStatus_ID)
END
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line2_CompletedDate + "' WHERE [Id] = " + IntToStr(Line2_CompletedDate_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line2_CompletedTime + "' WHERE [Id] = " + IntToStr(Line2_CompletedTime_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line2_ExpiryDate + "' WHERE [Id] = " + IntToStr(Line2_ExpiryDate_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = 'Completed' WHERE [Id] = " + IntToStr(Line2_OrderStatus_ID)
END
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line3_CompletedDate + "' WHERE [Id] = " + IntToStr(Line3_CompletedDate_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line3_CompletedTime + "' WHERE [Id] = " + IntToStr(Line3_CompletedTime_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = '" + Line3_ExpiryDate + "' WHERE [Id] = " + IntToStr(Line3_ExpiryDate_ID)
Sql1 = "UPDATE ProductionDataField SET [DataValue] = 'Completed' WHERE [Id] = " + IntToStr(Line3_OrderStatus_ID)
END
END
SQLEnd(statusSQL)
END
INT FUNCTION getLine1_Qty()
RETURN Line1_Qty
END
INT FUNCTION getLine1_CompletedQty()
RETURN Line1_CompletedQty
END
STRING FUNCTION getLine1_OrderID()
RETURN Line1_OrderID
END
STRING FUNCTION getLine1_BatchID()
RETURN Line1_BatchID
END
INT FUNCTION getLine2_Qty()
RETURN Line2_Qty
END
INT FUNCTION getLine2_CompletedQty()
RETURN Line2_CompletedQty
END
STRING FUNCTION getLine2_OrderID()
RETURN Line2_OrderID
END
STRING FUNCTION getLine2_BatchID()
RETURN Line2_BatchID
END
INT FUNCTION getLine3_Qty()
RETURN Line3_Qty
END
INT FUNCTION getLine3_CompletedQty()
RETURN Line3_CompletedQty
END
STRING FUNCTION getLine3_OrderID()
RETURN Line3_OrderID
END
STRING FUNCTION getLine3_BatchID()
RETURN Line3_BatchID
END
FUNCTION dbTest()
INT counter = 0
STRING Sql1
STRING Sql2
STRING Sql3
STRING Product_ID = "Biscuit"
result = ""
END
END
END
Sql2 = "SELECT SetId FROM ProductionDataField WHERE (Field = 'order status') AND (DataValue = 'pending') AND (SetId IN (" + result + "))"
result = ""
END
END
IF counter = 0 THEN
Line1_BatchID = SQLGetField(statusSQL , "DataValue")
END
IF counter = 1 THEN
END
IF counter = 2 THEN
END
IF counter = 3 THEN
END
IF counter = 4 THEN
END
IF counter = 5 THEN
END
IF counter = 6 THEN
END
IF counter = 7 THEN
END
IF counter = 8 THEN
END
END
IF counter = 0 THEN
Line2_BatchID = SQLGetField(statusSQL , "DataValue")
END
IF counter = 1 THEN
END
IF counter = 2 THEN
END
IF counter = 3 THEN
END
IF counter = 4 THEN
END
IF counter = 5 THEN
END
IF counter = 6 THEN
END
IF counter = 7 THEN
END
IF counter = 8 THEN
END
END
IF counter = 0 THEN
Line3_BatchID = SQLGetField(statusSQL , "DataValue")
END
IF counter = 1 THEN
END
IF counter = 2 THEN
END
IF counter = 3 THEN
END
IF counter = 4 THEN
END
IF counter = 5 THEN
END
IF counter = 6 THEN
END
IF counter = 7 THEN
END
IF counter = 8 THEN
END
END
END
END
END
SQLEnd(statusSQL)
END
STRING FUNCTION getresult()
RETURN result
END
STRING FUNCTION getresult2()
RETURN result2
END
</pre>
