Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
SHIFT TO THE LEFT! SHIFT TO THE RIGHT!
POP UP, PUSH DOWN, BYTE, BYTE, BYTE!
www.control.com/rss/
We have one compressor of GA30 (Atlascopco). In which when we start that compressor during starting one message is come. Message is "Wrong Phase Seq". Please advice me how to solve that problem.
I think operational panel is faulty. Becasue in that compressor not any contactor ON.
If your company is based in Malaysia, try email to info@orieus.com. They probably could solve your problem.
Interchange the phases at the supply panel.
The problem in your compressor is of the main 3 phase supply. You have to make a few attempts by changing phase sequence at main input to compressor and the problem shall be solved.
The problem is not neccesarily phases if this compressor has been running without power or motor changes recently. If your coupling is damaged you would get the same message. The regulator cannot see phases. What it does is watch for an increase in outlet temperature. If it's not there it assumes wrong phase but a broken coupling and even missing a phase can cause this.
Related articles from Control
Engineering magazine- Rockwell Automation introduces virtual design and production software utility
- FactoryTalk industry-specific applications launched
- Upgraded communication modules make PLC to PLC communications easier
- Torque: Hall-effect sensor, reaction torque sensor, torque data acquisition
- Transient blocking circuit protection via acquisition
- Automation Fair event focuses on convergence, sustainability, and technical talent
- Rockwell Automation releases VantagePoint for plant data visualization
- Allen-Bradley MicroLogix 1400 controllers released
Subject to its Terms of Use.
