<p>I try to write protocol using Mscomm with VB connecting to Micrologix. Using a timer to read from Micrologix with protected Read (N7:00 to N7:20). It runs fine. But when I write a value to any one of the Integer (say N7:01 with value 1), the value I read back is OK, but always halted for a moment then back to normal.
<p>Example:
<pre>
If writevalue = 0 then
performed Protected Read Function
else
Performed Protected Write Function
end if
</pre>
<p>Am I correct to do this?
<p>Thanks,
<p>Jet
<p>Example:
<pre>
else
end if
</pre>
<p>Thanks,
<p>Jet
