Pig Launcher
A PIG is a high tech device used to ascertain the condition of a underground gas line.
The PIG launcher/reciever stations are a specific location in the gas line designed to launch/receive the PIG.
Basically, you obtain a PIG; place it in the launching pipe and release it. It uses gas flow to move it through the pipe at a defined rate (so that it may obtain data). When it has reached it's destination, it is extracted from the PIG recieving station.
CTTech
N
A "pig" is a device that is inserted into a pipeline in order to clean the pipeline. It is inserted into the pipeline via a launcher and removed via a receiver.
It's called a pig because originally that was what was used... hopefully they killed the poor animal first!
Incidentally, when I was working in the Middle East they frowned upon calling them "pigs", preferring "spheres".
R
rohit singh baghel
pig launcher is a device use to launch a pig,it dia genraly 4 to 6 inch more than pipe from where it is connected,the perpouse of pig launcher to clean the pipe,or while transmitting the diffrent fluid from same pipe we introduse one or more pig to separate these fluid and pig will place by pig launcher.
