Magelis HMI and GE Fanuc PLC
Schtiel
Can I connect Magelis HMI panel to GE Fanuc PLC (Series 90-30, VersaMax, RX3i) via Ethernet? Is it possible (GE Fanuc doesn't support Modbus TCP)?
Do I need any additional drivers for Vijeo Designer? Where can I get them?
Thanks!
G
Gustavo A. Valero P.
I hate to tell you but I think it's 100% possible!! :)
I think that using an Ethernet Interface TCP/IP Module (PN: IC693CMM321) at PLC side you will read the PLC's data from any HMI or software able to support Modbus TCP/IP.
If your GE Fanuc 90-30 is old, you must upgrade its firware in order to use CMM321. The firmware last version is 8.x and its part number is 44A731232-G16 (CPU331 Upgrade Kit latest revision).
I hope it helps you.
Best regards.
Saludos.
BIConsulting C.A.
Valencia - Venezuela
gustavo.valero @ biconsulting. com
But what should I do with VersaMax that has an integrated Ethernet port and doesn't support MODBUS TCP?
I don't understand why MAGELIS supports all other PLCs but doesn't support GE FANUC :(
