R
When I execute an ipconfig command on the Command Prompt in my Windows 98SE system it gives the details as follows:
0 Ethernet Adapter:
IP address: xx.xx.xx.xx (x stands for the IP addresss numbers)
Subnet Mask: 255.0.0.0
Default Gateway: xx.xx.xx.xx (same as IP Address)
1 Ethernet Adapter:
IP Address: 0.0.0.0
Subnet Mask: 0.0.0.0
Default Gateway:
2 Ethernet adapter:
IP Address: yy.yy.yy.yy
Subnet Mask: 255.255.0.0
Default Gateway:
My questions are as follows:
1) I have only one LAN card in the system then what are the other Adapter informations about? (0 Ethernet Adapter, 1 Ethernet Adapter, 2 Ethernet Adapter)
2) Which IP is the IP of my PC?
au revoir
Rahul
0 Ethernet Adapter:
1 Ethernet Adapter:
IP Address: 0.0.0.0
Default Gateway:
2 Ethernet adapter:
Default Gateway:
au revoir
Rahul
