Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
"Yeah, but you're taking the universe out of context."
www.control.com/rss/
In the "MODBUS over serial line specification implementation guide", RJ45 connectors are recommended. So, how does this comply with the fact that MODBUS RTU supports daisy chaining?
Are there any Modbus RTU RJ45 cables or connectors that make it possible to connect in a daisy chain style? I mean, normally RJ45 is an endpoint.
Thank you for your time.
Most of my experience connecting serial Modbus devices has been with screw terminals or DB connectors. I have seen a few RJ45 drops in my time, and folks like Phoenix Contact and others make DIN rail mountable RJ-45 to screw terminal breakout connectors such that you could run your serial backbone from screw terminal to screw terminal on the connector and then drop to your device with RJ45.
Use a Cat5 and RJ45 breakout to make a RS485 tap.
There are many choices:
1. Phoenix contact's 5543630
http://www.alliedelec.com/Search/SearchResults.asp?N=0& Ntk=Primary&Ntt=5543630
2. Weidmuller's 8555440000
http://www.weidmuller.com/downloads/pdfs/literature/SSB_ G001-G046_Interface_units_GB.pdf
3. Industran's RJ45-U-SM-BRK or RJ45-F-SM-485
http://rj485.com/index.php?main_page=product_info &products_id=7
or
http://rj485.com/index.php?main_page=product_ info&products_id=14
or
WAGO also has an extensive line of RJ-45 to terminal block interface modules. See the following link:
http://www.wago.com/wagoweb/documentation/navigate/nm7d__ _e.htm
If you don't see what you need. WAGO will also design, build, deliver interface modules to your specifications.
The adapters above are all RJ-45 female jacks (technically '8P8C') to screw terminal blocks.
The NVT NV-RJ45A is an adapter with RJ-45 plug (male) to a screw terminal block.
Dan
Dan
Related articles from Control
Engineering magazine- ODVA announces new editions of CIP network specifications and testing of Ethernet/IP products
- Molex releases new connection system and expanded line of Ethernet switches
- Synapse Wireless California Eastern Laboratories form partnership
- Prosoft introduces wireless 802.11g point I/O adapter and appliance transaction manager
- Belden releases new continuous flex Ethernet cables
- Easier startup: Petropiar Oil Refining Facility is 2008 HART Plant of the Year
- Embedding wireless: one chip, security platform
- Wireless manager for instrumentation and control devices
- New podcast: One road to wireless instrumentation
- Upgraded communication modules make PLC to PLC communications easier
Subject to its Terms of Use.
