We want to modify some test equipment we have. Currently, that piece of equipment basically heats up the liquid in it to a certain temperature (based on user input in computer program) and then stops. It kicks back in once the liquid's temperature reaches the lower limit. Our goal is to somehow make the cooling process faster by adding some sort of cooling coil and fan next to the unit. Once the high limit is reached, we want the liquid to circulate through this cooling coil and have the fan turn on.
Basically we want a temperature sensor to send a signal to the unit and have the unit turn on the fan and open the 3-way solenoid valve (to circulate the liquid through the coil). As long as the temperature of the liquid remains between the upper and lower limit, the fan will stay on and the solenoid valve open. We don't care about controlling the fan's speed. Even if the fan runs at maximum speed during the entire time that the lower limit is reached, we are fine with that. Once the liquid cools down, we want the solenoid valve to close and shut off circulation and the fan to turn off too.
One last thing, we would like for this unit to accomodate liquid temperatures of upto 300 degrees F. Let me know if you have any recommendations or suggestions. Thanks in advance.
