Could someone help me? I have many solenoid valves 5/2 Lucifer with P/N 341S1120, used in common manifold. Some of them have defective o-rings. I tried to find out about it but it's already obsoleted. Can you give me the other model that is similar for replacement? The valve thickness should not more than 20 mm in order to suit the place.
Thanks,
Nawawi
Thanks,
Nawawi
