Experience with HMI on Linux
Human-Machine Interface and SCADA. topic
Posted by schmidt on 20 September, 2007 - 10:06 pm
Has anybody experience with SCADA software running on Linux?
Can you give any references?
Posted by kw on 21 September, 2007 - 11:33 pm
We use for over twenty years the "aprol" software (http://www.aprol.com) with the SUSE Linux distribution. No Problems! ...and we have a lot of fun.
KW
Posted by Anonymous on 22 September, 2007 - 12:36 am
I'm running a SCADA application (my own program) on Linux. It communicates with 15 PLCs, tens of barcode readers, 6 inspection cameras, and many printers. That machine also run Apache WEBserver for HMI and SQLite for database and archiving. The machine has been installed 18 months ago and it is running 24X7, real-time. I never rebooted the Linux server.
To conclude, I can't recommend a SCADA application but I can say that Linux is an excellent platform for robust applications.
Posted by Schauerte on 23 September, 2007 - 7:23 pm
We are useing pvbrowser.
It is very dynamic and we run the server on VMS and linux. The client is used on linux and windows.
First we used it for simple hmi's with labels, buttons, tables and xy graphics.
But now pvbrowser is capable of useing SVG graphics. We now are also useing autocad drawings and convert them to SVG. The SVG's are then animated from our simulation models and our process variables.
Posted by Rainer on 25 September, 2007 - 10:47 pm
Here is an example of using http://pvbrowser.org
for automation of biogas plants.
http://www.awite.com
http://www.awite.com/cms/front_content.php?idcat=83
http://www.awite.de/cms/upload/downloads/AUT/ALLG/Awicontrol_Teil_3 _Bsp_BGA-2006-08-07.pdf
Posted by joaq on 6 February, 2012 - 4:22 am
now, at 2012 Pvbrowser for me is wonderful, we have already tested it with modbus RTU ant TCP and works smoothly.
and has a very active community.
very nice project, yeah
Posted by emilio mastriani on 25 September, 2012 - 7:28 am
It is very interesting!!! We are trying to propose it as a solution but I I don't have specific information about hw...
Do you benchmark?
Best Regards,
Emilio
>> Here is an example of using http://pvbrowser.org for automation of biogas plants.
Posted by pvbrowser on 25 September, 2012 - 9:14 am
In which protocols are you interested in?
http://pvbrowser.org/pvbrowser/index.php?menu=4&left=8
Posted by david mertens on 26 September, 2012 - 3:27 am
WinCC OA supports Windows, Linux and Solaris.
One of the great advantages of WinCC OA is the fact that WinCC OA is completely platform neutral.
You decide which is the best operating system for your special needs. And you can mix platforms within your project:
Run Eventmanager on Linux, Userinterfaces on Windows or in any other combination.
Posted by Paul Jager on 25 September, 2007 - 11:49 pm
Yes, for the past decade too. There are servers running in major paper companies, oil and gas, metals and a full system based on Linux for electrical utilities in China. Basically a replacement for DCS/PLC and includes the HMI via X-Windows.
http://www.automationX.ca
Paul Jager
Posted by Nathan Boeger on 6 September, 2011 - 10:58 pm
Ignition from Inductive Automation runs on Java and is fully Linux compatible.
You can install with apt-get on Ubuntu or with the command line.
http://inductiveautomation.com/scada-software
Nathan Boeger
"Design Simplicity Cures Engineered Complexity
http://notanotherindustrialblog.blogspot.com
Posted by kxhmi on 7 October, 2011 - 1:42 pm
Kinesix (http://www.kinesix.com) has HMI software named Sammi that natively runs on several Linux platforms.
Receiving a million dollars tax free will make you feel better than
being flat broke and having a stomach ache.
-- Dolph Sharp, "I'm O.K., You're Not So Hot"
Advertise here
Advertisement
our advertisers
