I have a device whose input is x and output is y. y and x are related by the equation
y = 1/(1-e^(-x)).
How I got this equation is described as follows: I Injected input y beginning from minimum and kept recording x for each y. I incremented y bit by bit and plotted x. I found it to be a S-shaped curve. I searched the internet and found a general S-shaped curve's equation.
Most textbooks relate equations with respect to time. Mass Spring systems, Heat transfer equations, etc. because all of those equations are described by time derivatives of changing parameters. In my equation there is no 't'. Can this system still have its transfer function? Should time 't' be always a part of the transfer function?
y = 1/(1-e^(-x)).
