H
Dear All,
There are so many articles on the pros and cons of adopting a field bus communication system. Profibus and Foundation Fieldbus are the most talked about versus the conventional 4-20mA HART powered system.
Especially when it comes to the buses, everybody tries to convince others that his proposed bus is better and brings so many reasons. Each bus has its own fans, which technically are not low in profile as well.
There is a STP to be constructed. The control system has been dictated to be a DCS (no chance for SCADA!), and we are deciding the type of field communication network.
There is a large number of Discrete I/O, say for the limit switches of the valves or Start/Stop commands to the pumps, etc.
There is quiet a large number of Analog I/O as well and the plant is a rather vast, i.e. units are physically distributed.
The question is, shall we go for a Profibus PA network along with a Profibus DP or shall we select a Foundation Fieldbus or no, just have the conventional 4-20 mA system with HART?
Selecting a bus, I think the saving made by fewer cables, JBs, cabinets, I/O cards, etc. will not cover the money involved in more expensive instruments. The point is all the equipment in the plant should be bus compatible, e.g. a normal limit switch.
Should a bus be selected, I am more inclined to choose Profibus as the devices are a little less expensive compared to that of Foundation Fieldbus and also, there are so many Vendors for the STP which are European, so Profibus is more convenient for them as well. To communicate with other vendor packages I guess Modbus would be a good choice and of course there will be an Ethernet for non critical communication issues as well.
For selecting the right bus for communication in the field, I need a clear "detailed FINANCIAL view" of the alternatives in terms of:
- Initial investment for the hardware (All inclusive, i.e. the instruments, cables, JBs, earth work, trays, labor cost, etc.)
- Running operational cost (Operation, troubleshooting, spare parts, technical support cost, etc.)
I need expert comments on this subject with some detailed "indicative financial figures".
Thanks in advance,
Hamid
Thanks in advance,
Hamid
