L
Hi!
I had a problem recently regarding the balancing of load of the paralled generator. Can you give me some details on how to perform some adjustment for speed droop so that the load is equally distributed? Why is it that sometimes the kw reading is same for two generators but the amperes are different? Thank you and waiting for your reply.
Our system uses electric governor.
