Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
What does it mean if there is no fortune for you?
www.control.com/rss/
hello,
i have installed simatic wincc flex 2005 sp1 in my laptop. no problem was there while installing but after installing whenever i am trying to open that software a message is displayed "no valid licence key found. the application will be closed"
plz help if anybody had experienced the same problem.
The check list is as below:
1. Check your License for the Flexi
2. If no problem with the license you have, download the hot fix available on the Siemens site. These are real funda problems from Siemens.
Hi Sarabjot,
What OS do you have? You may get this problem if you installed it on XP Home.
You can also get more info from the help file "InstallationGuide2005.pdf" which can be found on your installation directory, e.g., ...\Siemens\SIMATIC WinCC flexible\WinCC flexible 2005\Help.
Lito
Lito
If you downloaded that software what you have is software with no license. The SP1 was intended to be used as an upgrade to WinCC Flex 2005, but it is actually a full install. This is the way Siemens sometime does upgrades. In order to actually run the software you will need a license, which must be purchased.
Related articles from Control
Engineering magazine- Pushbuttons, in 3 sizes, change colors
- Arctic HMI: Human-machine interface performs in harsh Arctic Circle conditions
- From IT integration to panel building, one mine at a time
- Gantry-Style Automated Accumulation
- PACMotion certified in compliance with PLCopen for motion control standard
- Packagers suggest integration improvements
- Integrators play central role in packaging automation
- Rockwell Automation introduces virtual design and production software utility
Subject to its Terms of Use.
