member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
If A equals success, then the formula is _A = _X + _Y + _Z. _X is work. _Y
is play. _Z is keep your mouth shut.
-- Albert Einstein
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
Explosion Proof Enclosure
Application Questions and Problems topic
Posted by Anonymous on 21 October, 2007 - 5:08 pm
Dear All,
I have one query regarding the explosion proofing of Junction box. I have a pressure switch in field commected to JB & going to control room. I am connecting pressure switch to DCS through a barrier. Can i stil use EEx'd'
junction box even after connection the switch through barrier. Once i connect the switch through barrier is it that whatever may be thr junction box like Exi, EEXe or EEx'd'.
Posted by Bruce Durdle on 22 October, 2007 - 5:09 pm
Be aware that the pressure must meet the requirements for "simple apparatus" if it is to be used on an IS circuit and is not itself certified as IS. This means that there are restrictions on any additional circuits used - usually not a problem. There are again no limits on how you connect the IS circuit and it is permissible to use an Ex d terminal box. However, there are a couple of things to check: - If there are other non-IS circuits in the Ex d junction box, you need to be very careful to maintain the required separation between Ex i and non-Ex i circuits - usually at least 50 mm unless there is earthed metal between. - You need to make it clear by labelling or in some other permanent way that the JB contains Ex i circuits.
Bruce
Posted by Steve Yates on 23 October, 2007 - 12:46 am
How will the IS signals enter/leave the Ex'd' junction box? It will be far easier if they are in separate cables and you don't try to mix them with non IS signals in the same multicore.
Steve
www.mtl-inst.com
Posted by Bruce Durdle on 24 October, 2007 - 12:14 am
Definitely separate cables...
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Internet Explorer 6.0 Fix
Advertisement
