Hi everyone,
I want to fill in an MS-Excel file with fields Address, Declaration, Name, Type, Initial Value, Actual Value and Comment of a DB, Data Block. I select and copy the whole line of DB specification table, in DB editor in LAD/FDL/STL, and paste it to the MS-Excel sheet, all of but Address field does paste. Please let me know if it is possible to paste the address field, and if yes, how?
I am using Siemens S7 with Wincc v6.2. When you need to use the "WinCC Configuration tool", a macro is added to MS-Excel when you install WinCC on your computer. I want to know if there is a simpler way to do it than the one above.
Best regards,
k.zonouzi ahmad
Best regards,
k.zonouzi ahmad
