S7 200 em 253 positioning module, stepper motor configuration
  • Thread starter sarabjot singh manku
  • Start date
Hi friends,
This is sarabjot from Nasik, Maharashtra. I am working in an automation company here. Our company has decided to go for one positioning control project.
We are going to control the position and speed of a stepper motor using em 253 positioning module with Siemens S7 200 PLC (CPU 222, version - 02.01). The difficult part is, we are not going to use Siemens stepper motor drive. Instead we are going to use a drive card manufactured by some other company.
If anybody can send me the wiring/connection diagram for this project, I will be thankful to him.
Stepper motor details:
Name: 35BYJ46 stepping motor
Model: 35BYJ46
Application scope: It is widely applied in air conditioners, computer peripherals (printer/duplicator/Fax machine), medical apparatus, stage lighting and industrial automation equipment.
Main technical paramaters:
Rated voltage 12VDC
Number of Pole 4
Speed Variation Ratio 1/64
Stride Angle 5.625‹ /64
DC resistance 200ƒ¶}7%(25Ž)
Idle In-traction Frequency >600Hz
Idle Out-traction Frequency >1000Hz
In-traction Torque >39.2mN.m(120Hz)
Self-positioning Tor >34.3mN.m
Insulated resistance >10MĦ(500V)
Insulated electricity power 600VAC/1mA/1s
Insulation grade A
Rise in Temperature <35K(100Hz)
Noise <35dB(100Hz,No load,10cm)
Weight About 40g
Notes:
Working voltage & frequency, rotate speed, the output shaft and color & length of conducting wire can be produced according to client's request.
Website: http://www.china-jiuling.com/encp-1.php?pid=4#d
Marc Sinclair
The EM 253 cannot drive a stepper directly, so stepper motor specificatins are no help here. The EM 253 will though, give step and direction pulses, which can be used by a motor/control card combination. The connections for this will depend on the control card interface. The siemens documentation shows several possibilities including differential inputs, which I have used most often. I have used many of these devices, not with stepping motors, but with servo drives with step and direction inputs.
Marc Sinclair
http://s7-200.germainesystems.eu
Because stepper is open loop position control? That you have cheaper solution with HSOutputs for stepper driver control.
