Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
The intelligence of any discussion diminishes with the square of the
number of participants.
-- Adam Walinsky
-- Adam Walinsky
www.control.com/rss/
Hi
I`m looking for schematic of a power supply that creates 4-20 mA current output adjustable.
I just want it to test analog cards of PLCs and simulate the transmitters for CPU in which the real transmitters have fault or dismissed.
I just want to volume the current from 4 to 20 mA
and its not important to know what is teh real current such as an indicator on the power supply .
Easy trick is to just use a potentiometer. Most cards have a 250 ohm input shunt to develop a 1-5 vdc signal on the DAC input, but some are 500 ohms. So a simple 5vdc supply and a pot from zero to 1.5K will do it. It's not exactly linear (OK, so it isn't even close to linear), but you said you don't care about accurate control, just swing the readings up and down, so this should work.
If you're uncomfortable with using a dinky little 5vdc because you may have cards with higher input impedances, then use a 24 vdc just like a loop and adjust the resistor values to suit.
Michael
Michael Batchelor
www.IndustrialInformatics.com
Industrial Informatics, Inc.
3281 Associate Dr.
N. Charleston, SC 29418
843-329-0342 x111 Voice
843-412-2692 Cell
843-329-0343 FAX
Michael
Michael Batchelor
3281 Associate Dr.
843-412-2692 Cell
843-329-0343 FAX
I'm not sure what industry you are in but back in the days when the MTL Application Notes were available on paper, our AN9003 "A User's Guide to Intrinsic Safety" had a circuit for a 4/20mA transmitter simulator that anyone could build, the current version which is only available in pdf format at present, doesn't have that circuit. If you would like a copy of the diagram, please send me an email offline and I will dig out an old copy and scan it for you.
Steve
www.mtl-inst.com
syates(AT)mtl-inst.com
Steve
www.mtl-inst.com
Related articles from Control
Engineering magazine- Siemens announces motors, drives, and motion control advances
- ODVA announces new editions of CIP network specifications and testing of Ethernet/IP products
- Molex releases new connection system and expanded line of Ethernet switches
- Wurldtech Achilles cyber security testing
- OMAC guidelines ease design, programming, integration
- Webcast to examine best practices for adopting Microsoft Windows Vista
- Vision sensor inspects for defects at any part position, rotation
- Smart vision sensor features simple setup, high-speed inspection
- Cameras with DSP coprocessors offer multiple options
- GHS has EAL6+ operating system security certification; launches Integrity Global Security
Subject to its Terms of Use.
