First, you should know the model of the panelview and the model or series of the PLC to be integrated. Go to the following link in the operator interfaces, select the panel view by its model, you will be able to access the literature that AB has available. Its a matter of take some time to read. Another option is, if you have identified the models you will integrate, you can contact AB, their technical support representative would give you information and links to the specific literature you need.
